Forza Horizon 3 PC Performance Review
Control Options
Control Options
Forza Horizon 3 can be controlled using GamePads, keyboard and mouse as well as steering wheels, all of which have rebindable controls. This is fantastic for a PC game, allowing players to effectively use whatever control method they wish, giving them an unparalleled level of choice.
 Forza Horizon 3 PC Performance Review  Forza Horizon 3 PC Performance Review
Below is a list of Steering wheels that are officially supported by Forza Horizon 3, with the game supporting the same collection of wheels as the free to play game Forza Motorsport 6: Apex. We recommend that those using a different wheel test their hardware on Forza: Apex before they try Forza Horizon 3.
  • Logitech G27 Racing Wheel
  • Logitech G25 Racing Wheel
  • Logitech G29 Racing Wheel
  • Logitech MOMO Force Feedback Racing Wheel
  • Thrustmaster T300RS
  • Thrustmaster T500 RS Gaming Wheel
  • Logitech G920 Xbox One Wheel
  • Thrustmaster T150
  • Thrustmaster TX Xbox One Wheel
  • Thrustmaster TMX Xbox One Wheel
  • Thrustmaster RGT Force Feedback Racing Wheel
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
28-09-2016, 16:29:19
Darkdayzzz
To put things simply, we expected a little better from Forza Horizon 3, especially when the game costs £49.99 at launch for the base version.
1- EVERY new game costs that price honestly....so saying that really doesn't work imho.
Also my 4gb760 and i7-4790k I get around 45-50fps on high with a mix of ultra at 1440p....not sure if im doing something magical or not.... just my own testing is all.Quote
28-09-2016, 16:33:34
barnsley
Excluding the city area I have a relatively steady 60fps running on [email protected] 1440p. I've probably got about 30ish hours in the game already thanks to my preorder.
TBF at the rate they are going, it'll be pretty solid before you know it. Most of the bugs that I could produce pre launch had been patched it seems. I guess going into the game with a low expectation of the port helped me.Quote
28-09-2016, 16:57:02
WYP
You do make a very valid point, most AAA releases cost £40 or more these days on PC, though the non-digital/Xbox version can be purchased for cheaper. This is a clarification that I should have made better in the review.
It is pretty easy to gain extra GPU performance in this game, especially if you disable MSAA. CPU performance is where there can be problems, making it difficult to get a steady 60 in some areas.
I do believe that with some further work to reduce CPU usage that the game would be an almost perfect PC port. Sadly the standard needs to be somewhere and right now the standard most PC gamers set is 60FPS.
I hope that we will soon be getting a CPU patch for the game, as that would pretty much fix the only real issue with this game's PC version.
The performance on older hardware can be forgiven somewhat by how easy it is to gain extra GPU performance by turning off MSAA, though it is worth noting that the Xbox One version uses 4x MSAA.Quote
28-09-2016, 18:58:55
russler
£49.99 is hardly standard pricing (xbox copy on amazon £41.99) thats 16% more than a copy that can be re-sold, the bigger issue though is its £49.99 on Microsoft store only, so thats a price thats unlikely to change for a loooong time, with sites like cd keys ive never payed full rrp price for any new game and im sure im not the only one.Quote
28-09-2016, 21:19:05
dryii
I have a GTX 1080, but still run the i7-2600k (at stock speed) with 16GB RAM. This is the first game I've encountered which pegs my CPU at 100%, while the GPU rarely goes over 65%. Overall the game does run smooth on Ultra at 1440p. I do hope they can make some coding changes so my GPU is better utilized and I get a higher FPS (low 40's, peaking in the 50's right now).Quote
