Forza Horizon 3 PC Performance Review
CPU Performance and Memory Usage
When playing Forza Horizon 3 on PC we found that the game rarely used more than 7GB of system memory and was often performance limited by the CPU rather than the CPU in high-end systems.
Using our i7 6700K we tested the game with our overclock of 4.7GHz, at stock and with a variety of configurations where we turned off CPU cores or CPU threads in order to see how game performance was affected.
As we lowered the CPU to stock clock speeds and then turned off hyper-threading we can see that the games average framerates remain almost unchanged, though the game's minimum framerate does change drastically. Changing the i7 6700K down to a dual core 4-threaded model we find both a dramatic decrease in both average and minimum framerates.
Those with lower end CPUs will need to either turn down geometry detail settings and car detail settings down a lot or limit this game to 30FPS in order to achieve a stable framerate, as this game can be CPU bound on even today's flagship Z170 i7 CPU.
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
28-09-2016, 16:29:19
Darkdayzzz
To put things simply, we expected a little better from Forza Horizon 3, especially when the game costs £49.99 at launch for the base version.
1- EVERY new game costs that price honestly....so saying that really doesn't work imho.
Also my 4gb760 and i7-4790k I get around 45-50fps on high with a mix of ultra at 1440p....not sure if im doing something magical or not.... just my own testing is all.Quote
28-09-2016, 16:33:34
barnsley
Excluding the city area I have a relatively steady 60fps running on [email protected] 1440p. I've probably got about 30ish hours in the game already thanks to my preorder.
TBF at the rate they are going, it'll be pretty solid before you know it. Most of the bugs that I could produce pre launch had been patched it seems. I guess going into the game with a low expectation of the port helped me.Quote
28-09-2016, 16:57:02
WYP
You do make a very valid point, most AAA releases cost £40 or more these days on PC, though the non-digital/Xbox version can be purchased for cheaper. This is a clarification that I should have made better in the review.
It is pretty easy to gain extra GPU performance in this game, especially if you disable MSAA. CPU performance is where there can be problems, making it difficult to get a steady 60 in some areas.
I do believe that with some further work to reduce CPU usage that the game would be an almost perfect PC port. Sadly the standard needs to be somewhere and right now the standard most PC gamers set is 60FPS.
I hope that we will soon be getting a CPU patch for the game, as that would pretty much fix the only real issue with this game's PC version.
The performance on older hardware can be forgiven somewhat by how easy it is to gain extra GPU performance by turning off MSAA, though it is worth noting that the Xbox One version uses 4x MSAA.Quote
28-09-2016, 18:58:55
russler
£49.99 is hardly standard pricing (xbox copy on amazon £41.99) thats 16% more than a copy that can be re-sold, the bigger issue though is its £49.99 on Microsoft store only, so thats a price thats unlikely to change for a loooong time, with sites like cd keys ive never payed full rrp price for any new game and im sure im not the only one.Quote
28-09-2016, 21:19:05
dryii
I have a GTX 1080, but still run the i7-2600k (at stock speed) with 16GB RAM. This is the first game I've encountered which pegs my CPU at 100%, while the GPU rarely goes over 65%. Overall the game does run smooth on Ultra at 1440p. I do hope they can make some coding changes so my GPU is better utilized and I get a higher FPS (low 40's, peaking in the 50's right now).Quote
