Gigabyte GTX480 SOC Review
OC Guru, Test Setup and Overclocking
Published: 22nd November 2010 | Source: Gigabyte | Price: £350est |
OC Guru
The Gigabyte comes with a very useful overclocking tool, the OC Guru. This allows adjustments of GPU and Memory speed as you'd expect, but also includes color controls and, perhaps best of all, hot key swapping. This means you can have one highly reduced profile for your desktop and with a single button combo switch to a gaming profile.
Gigabytes dedication to green computing cannot be understated either as there is a specific green mode that helps tame the GTX480 when you're in a light-use situation. As you can see from the screenshots below the power-savings between the left-hand shot and the right hand "green" shot are significant.
Test Setup
Gigabyte GTX480 Super Over Clock
ASUS Rampage III Extreme
Intel i7 950 @ 4GHz
6GB Mushkin Redline RAM
Corsair AX1200 PSU
Noctua NH-D14
Windows 7 Ultimate 64-bit
We will be comparing against the biggest challenger to the Gigabyte, the MSI GTX480 Lightning as well as the reference card. It would be pointless to compare to any AMD efforts as the GTX480 is clearly streets ahead as a single card.
Overclocking
Although the GTX480 Super Over Clock is miles ahead of its reference compatriot already we were still able to increase the Core still further up to 865MHz and the Memory from 950MHz to 1000MHz at stock volts!
Moving our attention to increasing volts it took just 1.083v to get the card stable at 900MHz to match the Lightning overclock, team this up with a 1150MHz memory speed and you have one very powerfull overclock for not a lot of volts! You would think with this overclock at such low volts would mean we could really crank it for an insanely high final clock. Sadly we ran into a lot of driver stability issues, not full on system freezes but just the display driver crashing. Normally if you have gone past the cards limits the whole system will freeze and you know its time to stop, but the issues we ran into with this really did make us feel it wasnt the GPU core holding us back. None the less the 900mhz core on a 480 is very impressive for an aircooled card.
Wow it's a very nice job that Gigabyte has done. I'm wondering how their warranty and support will be for GPU's, if it's comparable to EVGA and they bring more non-reference cards like this well... They'll do really well! Comparing this card at stock the the reference card is quite impressive and the work Gigabyte put in, especially with technology that you can't pronounce ![]() |
