Gigabyte GTX780 Ti GHz Edition Review
Gigabyte GTX780Ti GHz Edition Review
So far the GTX780Ti has proven itself to be the weapon of choice if you're looking for the best single GPU performance available. As good as it is out of the box, it flies particularly well once a decent overclock is in place.
However, we're aware that not everyone is comfortable poking around with their £500+ purchase, and that's where a factory overclocked card can really start to shine.
To this end today we're looking at the Gigabyte GTX780Ti GHz edition, a factory overclocked card that comfortably passes the 1GHz barrier at stock, and with the Windforce cooler in place has the potential to go even further with the nVidia GPU Boost 2.0 technology.
By now you're all very familiar with the GK110 GPU, so let's crack on.
The two big changes for the GHz Edition are the inclusion of the Gigabyte Windforce cooler, and that big factory overclock that pushes the GPU to 1085MHz out of the box. This isn't far from the best manual overclocks we've obtained so hopefully the results should back up this potential performance.
ChipsetGeForce GTX 780 Ti
Memory Clock7000 MHz
Process Technology28 nm
Memory Size3072 MB
Memory Bus384 bit
Core ClockBase / Boost clock 1020 / 1085 MHz
Card BusPCI-E 3.0
Memory TypeGDDR5
Digital max resolution4096 X 2160(via a single HDMI connector and not supported with two DVI connectors)
Analog max resolution2048 x 1536
Card sizeL=292mm, W=129mm, H=43mm
Power requirement600W (with two 8-pin external power connectors)
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Next»
11-12-2013, 15:45:47
ok very interesting but i was looking at and it does not show a back plate together, they made a mistake or what??Quote
11-12-2013, 17:01:53
Gigabyte only make one version of the 780 Ti Windforce so they should all have backplates.
11-12-2013, 17:12:17
Upside down text is unbelievable :/ The little slot for routing the power cables though, kudos for that great ideaQuote
11-12-2013, 17:38:18
The upside down text made me facepalm so hard.
Great review tho, it's a beast.Quote
11-12-2013, 18:29:12
Just paint the backplate white - solves the text issue and would contrast nicely with the black PCB underneath.
Might even remove the front fan shroud and paint that white too if doable.Quote
