Gigabyte GTX 1650 OC 4G Review
Published: 1st May 2019 | Source: Gigabyte | Price: £147.99 |
The Nvidia range is becoming quite crowded with the availability of the last generation of cards fighting for shelf space amongst the newest additions to the Turing range.
With the recent launches of the GTX 1660Ti and plain GTX 1660 we thought that every gap in the market had been filled, but Nvidia feel there is still the tiniest chink of light showing and have managed to produce the GTX 1650 to fill that crack. Demonstrating how highly they thing of the GTX 1650 we haven't got an Nvidia reference card available, but fortunately the partner manufacturers have stepped up to the plate and our first review of this new GPU comes courtesy of Gigabyte.
Indeed Gigabyte have tried to make the most out of the GTX 1650 by supplying it with their twin fan cooler, but without going too much beyond the MSRP Nvidia have set. We'll discuss the Nvidia MSRP later on, but for now let's find out what the GTX 1650 has to offer.
As with all these 'ever so slightly cut down from the preceding model' cards, there isn't much to say about the GTX 1650 that we didn't already cover in the GTX 1660 or GTX 1660Ti reviews. It's the Turing GPU we loved in the RTX cards but without the Ray Tracing and Tensor cores.
Keen readers will note that the GTX 1650 has 895 CUDA Cores, a big drop off from the 1408 we found on the GTX 1660. That very much puts this in the category of cards that are only really good for 1080P, so hopefully the GTX 1650 can still keep the image quality high at smooth frame rates. That's what we're here to discover. It might seem like we haven't much to say but at this price point performance is everything and the minutiae is much less important.
Of course we have to mention that the Gigabyte card we're reviewing today has a small factory overclock to hopefully squeeze some more performance out.
I'm kind of torn whether reviewers should focus on the unique card itselfthe shroud, the fans, the quality, etcor the GPU. On the one hand pretty much all shrouds and designs manufactured today by the likes of EVGA and Powercolor are adequate, and what distinguishes them from one another is usually a mere few degrees or a few decibels. Pay more, get more bling, get more cooling. Pay less, get less bling, get less cooling. It's quite simple really. So reviewing them on that merit seems like a tedious almost inconsequential thing, and instead reviewing it on the GPU itself would be more apt. But then once you've reviewed it you shouldn't have to review it again since performance will be the same.
I think your method of focusing on the card and not the GPU is fairest. I'm more in favour of that. |
I think it says a lot that Nvidia didn't give reviewers pre-launch drivers for the GTX 1650. Ultimately, the pricing problem is an Nvidia problem, but you can't really say that Gigabyte made a bad card here.
The GTX 1650 is a very interesting card, especially when considering it as a low power HTPC GPU, or as part as an ultra-compact system with relatively little airflow. This is a great card for throwing into an old OEM PC that needs a decent low power GPU for PC gaming.Quote
Ive just finished retesting an RX570 (had to get AMD to send one, all my originals went back to vendors)
So we will have a GPU focused review next weekQuote
I think your method of focusing on the card and not the GPU is fairest. I'm more in favour of that.Quote
