Gigabyte RTX 3080 Gaming OC 10G Review
Microsoft Flight Simulator
A title that doesn’t just require you to have some beefy hardware to maximise the visuals, but also a fairly empty hard drive to squeeze on one of the largest install sizes on the market, the newest instalment in the famous Flight Simulator series is gorgeous. Without any combat you’ve plenty of time with which to appreciate the satellite based ground imagery as well as the hand-crafted airports. With all the detail settings maximised it’s a stern test of your system.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Next»
17-09-2020, 13:20:56
Kaapstad
Thanks for all the hard work Tom it must have taken a lot of time and long hours to do the testing, I will link these reviews over at OcUK when their site starts working again.Quote
17-09-2020, 13:24:16
AlienALX
I echo the above. Thanks Guv.Quote
17-09-2020, 17:16:38
Deadtroopers
Champion reviewing.
Not to detract from that, there is zero here or in the other two that makes me stifle the yawns. Coolers with the last fan half/three-quarters overhanging and all, TUF apart, tacky placcy. If all the partner cards are going to be this naff, if I pull the trigger it will be FE all the way; if I need more performance or to keep the heat down, I'll put a block on it.Quote
