Gigabyte RTX 3080 Gaming OC 10G Review
Temperatures and Power Draw
Modern graphics cards no longer rely upon the user to overclock them, as the drivers now make the most of any spare power or thermal headroom available to boost the clocks to give the smoothest performance. Thus the temperature graph is a little less important than it used to be unless the manufacturer has created a godly cooler, whilst Power Draw is fun on your energy bill, but most of us just care about performance rather than a handful of Watts here and there. With slight variance in ambient temperatures we're also including the delta temperature too, so you know exactly how well the card performs relative to the air temperature.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Next»
17-09-2020, 13:20:56
Kaapstad
Thanks for all the hard work Tom it must have taken a lot of time and long hours to do the testing, I will link these reviews over at OcUK when their site starts working again.Quote
17-09-2020, 13:24:16
AlienALX
I echo the above. Thanks Guv.Quote
17-09-2020, 17:16:38
Deadtroopers
Champion reviewing.
Not to detract from that, there is zero here or in the other two that makes me stifle the yawns. Coolers with the last fan half/three-quarters overhanging and all, TUF apart, tacky placcy. If all the partner cards are going to be this naff, if I pull the trigger it will be FE all the way; if I need more performance or to keep the heat down, I'll put a block on it.Quote
