Gigabyte RTX 3080 Gaming OC 10G Review
Borderlands 3
Borderlands 3
Borderlands 3 saw Gearbox Software return to developing their most famous IP following the somewhat dubious reception The Pre Sequel received. Borderlands has plenty of settings to tweak and, despite looking superficially similar to Borderlands 2, it’s significantly more demanding upon your hardware. At higher resolutions only the most performance rich need apply. Naturally we run with everything at the maximum possible settings.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Next»
17-09-2020, 13:20:56
Kaapstad
Thanks for all the hard work Tom it must have taken a lot of time and long hours to do the testing, I will link these reviews over at OcUK when their site starts working again.Quote
17-09-2020, 13:24:16
AlienALX
I echo the above. Thanks Guv.Quote
17-09-2020, 17:16:38
Deadtroopers
Champion reviewing.
Not to detract from that, there is zero here or in the other two that makes me stifle the yawns. Coolers with the last fan half/three-quarters overhanging and all, TUF apart, tacky placcy. If all the partner cards are going to be this naff, if I pull the trigger it will be FE all the way; if I need more performance or to keep the heat down, I'll put a block on it.Quote
