Gigabyte RTX 3080 Gaming OC 10G Review
Control
Published: 17th September 2020 | Source: Gigabyte | Price: |
Control
Remedy Entertainment’s Control is one of those games that demonstrates everything available to you in modern engines and with modern hardware. Not only does it have destructible environments but it supports all the hardware tricks, including Ray Tracing and DLSS on hardware with either or both of those features. We’re testing in every possible combination to demonstrate how each can impact your frames per second. The first graph is all resolutions in 'plain' mode. The second graph with Ray Tracing on, and the third graph with Ray Tracing and DLSS on and off for performance impact demonstration purposes.
Not to detract from that, there is zero here or in the other two that makes me stifle the yawns. Coolers with the last fan half/three-quarters overhanging and all, TUF apart, tacky placcy. If all the partner cards are going to be this naff, if I pull the trigger it will be FE all the way; if I need more performance or to keep the heat down, I'll put a block on it.Quote
