iiyama Prolite E2403WS 24" TFT
Packaging & Appearance
Published: 7th August 2008 | Source: AfterHours | Price: £253.73 |
It's a well known fact that couriers like to play football with whatever they happen to have in the back of their delivery vans. For this reason, heavy yet fragile items such as TFT's need to be adequately protected against knocks, bumps and the occasional flattening by a 2 tonne Transit van. As we can see from the images below, the iiyama E2403WS is protected by a double-walled cardboard box, complete with a moulded polystyrine inner shell that provides the TFT with a reasonable degree of protection on all sides.
Contained within the box are all the basic cables to get you up and running along with an instruction manual and of course, the base. No driver disks are included, but unless you're unlucky enough to be running anything prior to Windows XP, your OS shouldn't have any problems using the screen to its full advantage. Pictured above-right are the three cables included in the box. From left to right these are: Speaker cable (3.5mm jack), D-Sub to D-Sub cable (regular VGA) and DVI to HDMI (for HD quality).
Constructed entirely from black plastic with a 20mm bezel around the top and sides of the screen, it has to be said that the iiyama E2403WS looks rather bland and doesn't really do much to seperate itself from most of the no-name brands on the market at the moment. Even just a hint of aluminium, some silver details or a proper badge could have spiced things up a bit, but in comparison to the likes of Dell, ASUS and Samsung the iiyama pretty much sent us to sleep.
Connectivity options are fairly standard for a TFT in the £250 price range, with VGA ,HDMI and Stereo jack being provided at the rear of the screen. As mentioned earlier in the review, the E2403WS has two speakers mounted just below the console at the front of the screen. Rated at 2w each, don't expect these to do much more than play basic Windows sounds.
Now that we've got to know the screen, let's see what she's like fired up!
Bit steep when the likes of the Yakuraa are about - also the comment about it having no DVI is a bit silly as it has HDMI (and came with a HDMI > DVI cable) which is just the same digital connection.Quote
Agreed with Phunky, I'd rather have an option of HDMI than DVI nowadays tbhQuote
Any suggestions for a good screen under £400 thats 24" or over, but importantly Performs well for Games/very high-end Video editing, good colour depth/contrast ratio? (have sli gtx 280s, QX9650 and 8 gig Ram)
Thanks in advance guys
regards
Ollie
Quote
regards
Ollie
For £250 pricing, 24", I don`t think u could mumble about any sort of slight bleeding or anything like that.
I`d consider this model tbh, if at the time I felt a Dell was too much
