inno3D iChill GTX980 Review
Unigine Valley
Unigine Valley
Even in Unigine Valley it's only a shade behind the best of the GTX980s, but requiring infinitely less faffing about to get up and running.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Next»
03-12-2014, 05:41:58
barnsley
Yay finally someone else sings the praises of Inno3D's rather bonkers cards.
The "iChill Herculez X4 Air Boss Ultra" cards are mad, my only real complaint is you can't seem to get them in their DHS flavour, so you could end up with a crap overclocker. If I wasn't constricted by card sizes/cooler types in my rig I'd get one.Quote
03-12-2014, 08:47:57
Asen
I know it's not about it, but the 980 Strix is aways above, even above this aircooled beast.Quote
03-12-2014, 08:55:41
tinytomlogan
The overclocked Strix is - the results for this are at stock. Admittedly the overclocking was a it meh thoughQuote
03-12-2014, 10:37:47
Dicehunter
Great review but you might want to change the version of GPU-Z you have on these screenshots as you're using 0.7.8 and the latest is 0.8.0 shows the proper stats for Maxwell, 0.7.8 shows incorrect numbers for -
ROPs/TMU's should read 64/128 but on 0.78. they show 32/170
Texture Fillrate should read 80-90 depending on the overclock and on 0.7.8 it shows 40
Pixel Fillrate should read around 160 depending on the overclock and on 0.78. it shows 200+Quote
03-12-2014, 14:17:00
NeverBackDown
Guess 50mm fans aren't useless then. I'm impressed by this card. Even though its odd looking
FYI Tom for CoH2, don't bother with SLI/Xfire. It won't work. That game is notoriously known for not working with it. It's the game engine design that doesn't utilize it right. AMD and Nvidia at around the game's launch actually recommends not using multi-gpu setups. Something to do with AFR and being CPU dependent. In fact its so dependent on the CPU that upgrading to a more powerful cpu will probably get you better results than adding another gpu.Quote
