Mirror's Edge: Catalyst PC Performance Review
1080p Testing with AMD R9 Fury X and Nvidia GTX 980Ti
Mirror's Edge Catalyst PC Performance Review
When moving to the higher end GTX 980Ti and R9 Fury X we can see that both GPUs offer stupidly high performance, to a point where at low settings the game is almost constantly sitting at the 200FPS framerate cap.
We can see here that in most cases the R9 Fury X and GTX 980Ti perform similarly, especially when we look at minimum framerates. While AMD's R9 Fury X has higher framerates on average, it still has the same performance dips as Nvidia giving no side a clear advantage until we go to Ultra and Hyper settings.
It is clear that of you own an R9 Fury X or GTX 980Ti you should either be using a super high refresh rate monitor or taking advantage of the games resolution scaling options, as this game barely presents a challenge to these high-end GPUs.
08-06-2016, 16:56:39
Dicehunter
Good to see the Fury X taking the performance lead in 1080P and 1440P Quote
11-06-2016, 15:27:31
Primey
Your hyper settings results are very weird.
https://www.youtube.com/watch?v=Bm5ZCJah-FY
Above video shows the 970 struggles with hyper settings because it is aimed at above very high vram cards yet you're saying the GTX 960 and 380 (both 2gb cards) manage hyper settings just fine? How can the 960 beat a 970 when it comes to hyper settings? Answer: It can't. Notice how in the video there's a 20 fps~ difference between ultra fps and hyper fps yet in your results the difference is only 5 or so fps AKA within margin of error.
I think you've messed something up, you didn't untick the gpu memory restriction settingQuote
