MSI GTX560-Ti OC SLI Review
3D Mark
3D Mark Vantage
We all know Vantage tends to prefer the nVidia cards because of the PhysX element in the testing. Even so the GTX560-Ti SLI setup does well, being comparable to nVidias own twin-GPU card the GTX590 and far ahead of the similarly priced GTX580. It's worth noting that as the AA gets ramped up in the higher quality tests the gap between the GTX560-Ti SLI and its competitors narrows hugely until on the Extreme setting many of our cards are neck and neck.
3D Mark 11
Dispensing with the nVidia-biased Vantage and moving to 3D Mark 11 the GTX560-Ti SLI doesn't quite match the GTX590 and falls somewhere between the HD6870 CF and HD6970 CF results.
«Prev 1 2 3 4 5 6 7 8 Next»
03-05-2011, 08:54:46
dugdiamond
very informative
shows that a single (duo) gtx590 is the way to go... £/fpsQuote
03-05-2011, 09:27:39
SieB
My review withdrawal systems are cured, thanks, Bryan
So for £400 a whole £150+ less than a 590/6990 you can get similar performance, not bad if you ask me. Sacrificing some AA in one game shouldn't really put you off and anyone with an AMD card can only have up to a maximum of 8x AA anyway.
If you have the money for a 590 that would ideally be the better option in the long run but if you are on a budget SLI MSI 560 TI's is a pretty damn good alternative.
Quote
03-05-2011, 09:37:36
Zeals
No tinkering with overclocks?Quote
03-05-2011, 09:53:03
Karlos_the_n00b
Originally Posted by dugdiamond View Post
very informative
Maybe, but don't forget that two 570's in SLI aren't listed in the bench results and there are many on the forums that speculate that they would be a better alternative to a 590. If your not looking for a single slot solution that is.
Quote
03-05-2011, 22:42:43
piotrekhc
One is enough for 98% of games out there, but who would say No to two of them , good review but I'm missing video.Quote
