MSI GTX960 Gaming Review
Temperatures and Power Draw
Temperatures
At stock the MSI Gaming is two degrees warmer than the ASUS Strix, although when overclocked the extra size of the Twin Frozr cooler enables it to be a degree cooler. Either way the MSI does well to keep things under control.
Power Draw
Although still barely drawing anything of note, the MSI with its fullsize PCB does require 20 Watts more than the ASUS. Not a significant amount but it shows what difference the larger PCB makes.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Next»
22-01-2015, 17:25:51
mikeyc33
I'll take 2 please Quote
22-01-2015, 17:59:43
Coolant
Too anemic in VRAM, and lots of older cards compare to it favorably in metrics that actually matter. For a new card, stretching to that 970 will make for a better bet.Quote
24-01-2015, 20:15:46
realneil
I love the looks of the MSI cards. I'd love to see what two would do in SLI.
Thanks for the review.Quote
25-01-2015, 00:26:40
Emu
My problem with the GTX 960 is that they are only a hundred or so dollars cheaper then the GTX 970 here in Australia. Why would I pay $350-$400 for a 960 when I can pick up a 970 for $450-$550? The 970 is miles ahead in performance and within the same power draw as the 960, i.e. if your powersupply can handle having a 960 in your computer then a 970 will be fine...Quote
