MSI GTX980Ti Lightning Review
Temperatures and Power Draw
Published: 16th September 2015 | Source: MSI | Price: £659.99 |
Temperatures
The cooler on the Lightning makes the most of its excellent fin density and three big fans to keep the card cool under even the most trying of circumstances.
Power Draw
Despite the extraordinary amount of inputs the Lightning is actually surprisingly frugal in the power department.
The RGB lights are obviously a nice touch but we firmly believe they would sell vast more quantaties of this card if you had comstomisable panels where you had black as the standard colour and you could add your own blue, red, white, green panels to suit your own system. If MSI had addressed this point it would have been a total slam dunk. |
JRQuote
I don't really understand this point? No other manufacturer currently does it so it can't be held as a negative against the Lightning. Is every card not getting an award until somebody does clip on parts?
JR |
More the fact MSI have dropped the yellow on newer boards because they dont sell. Thats from MSI directly btw. So if they had options for the Lightning to be able to have other colours to work with the RGB's it would sell chuffing loads.
JRQuote
JR |
I do think if some detachable parts or stickers for the yellow bits it would be easier to make the GPU look nice in a system. Multi colour lighting is useless for a GPU that is clearly designed to be one specific colour.Quote
