MSI RTX 2080Ti Duke Review
Ghost Recon : Wildlands
Published: 16th April 2019 | Source: MSI | Price: |
Whatever you say about Ubisoft they give you a lot of options to play with. Their South American squad sim has the Ultra preset, Subsurface scattering, Ultra long range shadows, Temporal AA, HBAO+, 16xAF, even the Enhanced God Rays. Because who doesn’t want their Divine Rays enhanced?
Whats the power limit on this card ?
EDIT: Power limit is definitely a deciding factor when buying this type of card, as most buyers wont get a cherry picked sample like OC3D. I suggest that its something you should incorporate into future GPU reviews. |
All the 2080 Ti cards are nice, it all comes down to cooling and warranty as to which is best for you.
I reckon you'll most probably hit power limit before cooling becomes an issue on this card..
My opinion on power is that I want more performance for less Watt per hour
PCIe Slot power 63W nominal, 74W max.
Each 8-pin power connector 143W nominal, 167W max
TGP 130W min, 260W rated and 290W max.Quote
EDIT: Power limit is definitely a deciding factor when buying this type of card, as most buyers wont get a cherry picked sample like OC3D. I suggest that its something you should incorporate into future GPU reviews.Quote
