MSI RTX 2080Ti Duke Review
Final Fantasy XV
Published: 16th April 2019 | Source: MSI | Price: |
Final Fantasy XV
Final Fantasy XV perfectly shows off the benefits to be found from the DLSS available on the latest nVidia cards thanks to their Tensor Cores. Image quality and performance are both boosted, a very rare combination indeed.
Whats the power limit on this card ?
EDIT: Power limit is definitely a deciding factor when buying this type of card, as most buyers wont get a cherry picked sample like OC3D. I suggest that its something you should incorporate into future GPU reviews. |
All the 2080 Ti cards are nice, it all comes down to cooling and warranty as to which is best for you.
I reckon you'll most probably hit power limit before cooling becomes an issue on this card..
My opinion on power is that I want more performance for less Watt per hour
PCIe Slot power 63W nominal, 74W max.
Each 8-pin power connector 143W nominal, 167W max
TGP 130W min, 260W rated and 290W max.Quote
EDIT: Power limit is definitely a deciding factor when buying this type of card, as most buyers wont get a cherry picked sample like OC3D. I suggest that its something you should incorporate into future GPU reviews.Quote
