MSI RTX 2080Ti Duke Review
Forza Horizon 4
Published: 16th April 2019 | Source: MSI | Price: |
Forza Horizon 4
The latest version of Playground’s excellent Forza Horizon series sees the Horizon Festival decamp to the UK. Unfortunately the developers didn’t bother to make the cars right-hand drive so it’s a little incongruous to play, but on the plus side they have optimised it extremely well for the PC. Everything to the stops, as befits such a gorgeous title.
Whats the power limit on this card ?
EDIT: Power limit is definitely a deciding factor when buying this type of card, as most buyers wont get a cherry picked sample like OC3D. I suggest that its something you should incorporate into future GPU reviews. |
All the 2080 Ti cards are nice, it all comes down to cooling and warranty as to which is best for you.
I reckon you'll most probably hit power limit before cooling becomes an issue on this card..
My opinion on power is that I want more performance for less Watt per hour
PCIe Slot power 63W nominal, 74W max.
Each 8-pin power connector 143W nominal, 167W max
TGP 130W min, 260W rated and 290W max.Quote
EDIT: Power limit is definitely a deciding factor when buying this type of card, as most buyers wont get a cherry picked sample like OC3D. I suggest that its something you should incorporate into future GPU reviews.Quote
