MSI RTX 4090 Suprim X Review
Test Setup and Clock Speeds
Test Setup
Any chance we get to revisit our test suite and revise it is going to be one we take. Some of our gaming benchmarks have become a little bit long in the tooth, so today we're making wholesale changes. Naturally some titles still hold up, and some are going to be new and therefore have relatively limited comparisons. We've also moved our graphs from portrait to landscape. Do not adjust your set.
AMD Ryzen 9 3950X
ASUS ROG Crosshair VIII Formula
Corsair Dominator Platinum RGB Series DDR4 3600MHz
Corsair HX1500i PSU
Corsair iCUE H150i RGB Pro XT AIO
Corsair MP600 2TB PCIe 4.0 SSD
Corsiar Obsidian 500D RGB SE
Windows 11
Clock Speeds
If the Founders Edition sticking close to its rated 2520 MHz wasn't enough for you, and the Gigabyte streaking past 2700 MHz left you cold, then the Suprim X has a rated OC of 105 MHz above stock but actually averages over 2800 MHz with a peak of 2835 MHz. That's a 2.8 GHz GPU, guys, gals and non-binary pals. Jaw-dropping.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 Next»
12-10-2022, 16:34:00
demonking
So this performs on par with the FE, roughly, losing in a lot of instances(unless the labels on some of the graphs are wrong?), draws more power and runs at a higher temperature and costs at least £200 more than the FE. was it at least quieter?
Now you see why EVGA has pulled out of Nvidia cardsQuote
12-10-2022, 21:45:32
AngryGoldfish
Yeah, it seems that gone are the days where it actually makes sense to buy an AIB partner card. They're more expensive and are not much better in cooling.Quote
13-10-2022, 07:31:29
Warchild
The issue for many of us not living in the UK/US is actually managing to get our hands on an FE card. I would have to import it direct from Nvidia and then pay 36% tax on it Quote
13-10-2022, 11:17:16
AngryGoldfish
Yeah, countries like Norway are very expensive when it comes to tax. Ireland has high tax and import duties as well, but some UK shops (Amazon for example) have deals where I can still buy items from the UK and only pay Irish tax, not UK tax AND Irish tax, which is what has happened with other places post-Brexit. Many of the shops I used to use from the UK I don't shop with any more. It's not right paying both UK and Irish tax.Quote
13-10-2022, 12:25:34
NeverBackDown
If you have friends over in those areas, you could give them the money to pay for it, then ship it to you? Will take longer but probably save you money.Quote
