OverKILL3D ASUS Matrix Platinum GTX980 4 Way SLI Review
Unigine
Published: 13th March 2015 | Source: ASUS | Price: your soul |
Unigine
There is a reason we say that we do these things so that you don't have to, and perhaps Unigine is the best example of this. Clearly at 'regular' resolutions a couple of cards is enough. It's only once you hit 4K that the Quad-SLI becomes a feasible solution, regularly doubling the frames per second of the SLI setup. So much power is available to us that it's impossible to set Unigine up in such a way that you go below the 60FPS VSync barrier. Yes, it looks as lush as you think it does.
i dont understand the extreme differences between websites with the same gfx cards 2xsli. like one site will say hitman absolution running at 75fps and you clocked 31fps at 4k. then the same site will have bioshock running at 67fps while you clocked 103fps at 4k. those are huge differences where you have a faster processor. the other site being a 3960.
JRQuote
JRQuote
