PowerColor HD4870 512MB PCI-E
Packaging & Appearance
Published: 24th July 2008 | Source: PowerColor | Price: £174.97 |
While some GPU manufacturers go for unneccesarily large and extravogant packaging with oodles of extras that often get pushed aside, PowerColor have always managed to keep a focus on value for money and as such haven't succumbed to this often expensive tactic in order to make their product stand out. This is very much true for the HD4870 on review today which is presented in a slimline cardboard box, not much bigger than the graphics card its self.
Rather than preying on the weaknesses of many geeks with images of scantily clad female CGI characters, PowerColor have decided to outfit the front of the HD4870 box with a CGI character fully dressed in armour, brandishing a rather large sword. While this may not have the same head turning effect as a 10" waist and an airbrushed 32FF bosom, the overall packaging design will most definitely still stand out on retailers shelves.
The cards itself is protected from any courier inflicted damage by an inner-inner box, effectively placing 4 layers of cardboard between the graphics card and the outside world. As previously mentioned, only the bare minimum accessories are included: S-Video cable, DVI-HDMI converter, DVI-VGA converter, Crossfire cable and a driver disk.
Unlike the HD4850 reviewed recently the PowerColor HD4870 features a dual-slot cooler designed to push the hot air out the back of the PC case. This is a much needed improvement, as the HD4850 was hot enough to to cook a Full English breakfast on. The warrior character also makes a reappearance on the top of the cooler and is thankfully quite easy to peel off should it not look at home inside your PC.
The stock ATI cooler is actually quite beefy and features a large copper base plate joined to rows of aluminium fins via several heatpipes. PowerColor/ATI also have to be given credit for using a reasonable quality thermal paste on the GPU core and for applying just the right amount. The memory chips and VRM's also receive cooling via thermal pads attached to metal assembly of the cooler, which at the very least should help disperse the heat.
Isn't there 8.7 catalyst drivers out now, apprently this gives an increase in peformance.Quote
Yeah I'm with Rasta on this one, you can benchmark something to the hills but have to put it in context with the rest of the equipment your using it on, I've had similar arguements with certain people (a family member who runs a water cooled 8800gt sli Q6600 rig but won't shell out for a decent monitor,he still has a 19inch curved 4:3 crt lg thats nearly 8 years old and refuses to part with it due to it costing him 600 quid "back in the day" go figure)......can anybody really notice wether fear is running at 130fps or 200fps....I think not....so picking cards on price per frame ratio I feel is a good balancing factor...kudos to OC3D for another good review...and good on ATI for finally stepping up to the challenge with there 4xxx series....Quote
Originally Posted by name='Jim'
Yeah. Was released about a day after we completed the benches of this card *sigh*.
Looking at this review, it`s an overly obvious competitor for the GTX260 - which is fine, and the pricing is -£20 or so to nVidia, which kinda puts a difference perspective on things.
The 280 being that much more.. well yeah ok it happens to be the better card out of the 4 without "competition" (used loosely here), and the trend here is "pfft we`ll charge whatever we like for it" - just look at Intel with it`s cpus that compare to the AMD cpus and those that are beyond comparison.
In terms of loosely labeling that there is no competition.. well that`s kind of a misleading statement today. All 4 of the cards reviewed will not be held back in any way by games u throw at it in comparison to each other. The distinction is that on paper some to 10,20,30, whatever frames more than the other - the other already doing awesome frames. And the looks.. all 4 will give u an immensely pleasing experience.
This for me is where the OC3D cost per frame blows many reviews out of the water. There has been need for a change in review styles. Benchmarking doesn`t mean what it used to, in terms of gaming, perhaps bracketing only. Quality of picture is very hard to put over, other than u have to accept that they`ll all output at the same quality-standard. So what`s left is what u pay for them...
The strong arguement in addition to this is the screen sizes, and I think this may get more of a question as monitors get cheaper and standard resolutions get bigger. 20-22" widescreens mainly operate at 1680x1050 - this is almost being the norm for me. 24" above can be the same, with quality models offering the higher resolutions again. There`s even larger monitors out there being used where perhaps 24" was in the past.
With these thoughts in mind, the size of monitor vS the cost of the cards vS the capability of the card at the standard resolution u want - u should pick out of the 4. Smaller resolution, 17/19" square - 4850 will be fine, 24"+ u may chose the 280 and be able to afford it considering what u already purchased.
It`s sad that performance isn`t the stickler for selection - but having `quality` become a replacement for it isn`t wholey a bad thing.
Great review again btw.
PS. need more bumpff, when will manufacturers learn that graphic cards and mobos need to be accompanied with misc bumpff! Don`t care too much what it is, but c`mon.Quote
