Sapphire 4850x2 2GB PCIe Graphics Card
UT3, Racedriver GRID & Company of Heroes
Unreal Tournament 3 is the highly anticipated game from Epic Games and Midway. The game uses the latest Unreal engine, which combines fast gameplay along with high quality textures and lighting effects. All benchmarks were performed using UTbench with a fly-by of the DM-BioHazard map. As usual, all benchmarks were performed 5 times, with the highest and lowest results being removed and an average calculated from the remaining three.
GRID
Race Driver: Grid is a visually taxing game that presents a challenge to any graphics system. Results were recorded using FRAPS to log the average FPS over a 2 minute race. To ensure consistency, the same track, car and general path of travel was used in each of the 5 benchmark runs for each graphics card, with an average FPS being calculated from the median three results.
Company of Heroes is Relic's first title to make use of the "Essence Engine". This engine was designed and coded from scratch by Relic in order to make use of special graphical effects, including high dynamic range lighting, dynamic lighting & shadows, advanced shader effects and normal mapping. On May 29, 2007 Relic released a DX10 patch for Company of Heroes which was applied for this test.  Running the in game performance test 5 times, the highest and lowest scores were omitted with the average calculated from the remaining 3.
Results Analysis
Predictably, the GTX stomps all over the 4850x2 in Unreal Tournament thanks to the PhysX processing but the tables are turned in GRID with the 4850x2 returning the favour. However GRID showed some texture and shadow corruption which is most likely due to immature drivers. Company of Heroes produced a mix bag of results with the 4850x2 winning out at higher resolutions.
Let's head over to the next set of benchmarks...
«Prev 1 2 3 4 5 6 7 8 Next»
27-12-2008, 17:27:12
zak4994
Awesome card.
You should have also compared it to a Radeon HD 4870x2 to see the difference between the reds.
At 1600x1200, the GTX280 had double the frames of the 4850x2 in Crysis.
More driver problems?Quote
27-12-2008, 17:34:56
SwaleSmith
Very intresting, can't beleive I'm saying this but the high end ATI cards especialy the 4870x2 are getting more and more tempting and with this card I guess once the drivers are ironed out its likely to be good.
The GTX295 so far hasn't impressed me much, I'd like to have seen a single card solution as in a sucessor to the GTX280 however it's somewhat unfair to jump to conclusions just yet.
So I we will wait and see but judging by the previous 9800 GX2 wich I owned but wasn't overly impressed by, I don't like the layout idea of two cards linked with an internal SLI connector....I'm sure you will be able to give us the low down on that soon enough though any dates on a review webbo???
Good ReviewQuote
27-12-2008, 17:44:22
w3bbo
Due to it being the xmas period we won't have any GTX295's to report on just yet but as the impending release date is expected to be mid/late January I would expect to read a review around that time .Quote
27-12-2008, 17:46:37
SwaleSmith
will keep an eye outQuote
27-12-2008, 17:59:32
monkey7
Meh... Noisy, bad driver support (worse than ATi itself... WOW) and about equal performance to the gtx280. Not to mention the fact that 2 cores on one card are harder to custom cool with air.
I was once hoping to go 4850x2, but now the only option I would remotely consider is another 4850 or a gtx260 216.
EDIT: good review though ^^Quote
