Sapphire 4890 Vapor-X PCIe Graphics Card
Gaming Benchmarks
Unreal Tournament 3 is the highly anticipated game from Epic Games and Midway. The game uses the latest Unreal engine, which combines fast gameplay along with high quality textures and lighting effects. All benchmarks were performed using UTbench with a fly-by of the DM-BioHazard map. As usual, all benchmarks were performed 5 times, with the highest and lowest results being removed and an average calculated from the remaining three.
Race Driver: Grid is a visually taxing game that presents a challenge to any graphics system. Results were recorded using FRAPS to log the average FPS over a 2 minute race. To ensure consistency, the same track, car and general path of travel was used in each of the 5 benchmark runs for each graphics card, with an average FPS being calculated from the median three results.
Call of Duty 4 is a stunning DirectX 9.0c based game that really looks awesome and has a very full feature set. With lots of advanced lighting, smoke and water effects, the game has excellent explosions along with fast game play. Using the in-built Call Of Duty features, a 10-minute long game play demo was recorded and replayed on each of the GPU's using the /timedemo command a total of 5 times. The highest and lowest FPS results were then removed, with an average being calculated from the remaining 3 results.
Results Analysis
The results above showed a mix bag of returns. Both COD4 and Unreal Tournament III showed both overclocked 4890's neck and neck with perhaps the Sapphire version just stealing the glory. However, GRID showed that raw GPU grunt counts in this arcade racing sim with the XFX outpacing the Sapphire card by a fair margin.
Let's move on..
«Prev 1 2 3 4 5 6 7 Next»
02-06-2009, 06:42:45
the card peforms extremely well, but the card looks horrible when will sapphire discover good looking card chassisQuote
02-06-2009, 07:29:13
Sweet review man, massive props to Sapphire for final sticking a non reference cooled card on the market. Any idea when these will be available?Quote
02-06-2009, 14:51:16
Nice review as always my good man!
I wasn't sure that these coolers would make much odds over other after market coolers but those temps are pretty damn good.Quote
08-06-2009, 12:40:40
very nice review!
Is that cooler good enought?Quote
30-06-2009, 18:05:52
Well actually I am not quite convinced. You see almost solely based on this review I went merrily our and promptly bought 2 of these cards only to find that .
1) They run a lot hotter than stated. 67 Celcius at idle and run so hot when gaming that my PC crashes. I haven't managed to record the temp just before crash-poin but I have seen it at upto a blistering 93 Celcius!
2) I don't get anywhere near the FPS stated in the article. Infact I get exactly the same when playing CoD World at War online with 2 of these cards in crossfire as I did with one 9800GTX+. Namely 91 FPS.
I have plenty of ventilation in my rig and the fans on the HD4890s are certainly working.
At +4000rpm (confirmed by ATIs own CCC program and CPUIDs Hardware Monitor) they are audible let me tell you.
I don't believe my system is to blame despite it not being cutting edge.
Sapphire recommend a bigger PSU. 650W-750W and monitoring my temps with rivatuner.
I have a 620W PSU and run Vista ultimate 64 bit, which doesn't allow rivatuner to work since I downloaded the latest update if you can call it that.
Sys Specs:- [email protected] with Thermalright Ultra-120 eXtreme cooler and Noctua NF-P12 fan. ASUS Maximus Formula Republic of Gamers motherboard with X38 chipset and 4 GHZ of Kingston HyperX PC9600 RAM @ 1207MHz being cooled with a Corsair Dominator Airflow Fan.
CoolerMaster Real Power M620 Modular PSU.
Vista Ultimate 64 bit OS.
Samsung SpinPoint T166 HD501LJ 500 GB.
All incased in a Aerocool Hi-Tech 7 cabinette with a 40cm fan on the side and 2 x 12cm fans, one infront and one at the back.
Any good advice would be appriciated.
Bilko out.Quote
