Tom Clancy's The Division PC Performance Review
4K Screenshot Graphical Comparison - Part 2
Sadly in this set of screenshots we can see that the small changes in in-game time have made a big visual difference in these screenshots, but we can still see a lot of the differences in the games visuals when moving up the settings.
Between low and medium we see that shadow quality improves greatly, with shadows having notably higher resolution and covering more objects. When looking at the feet of the player we can see the shadow cast by the Happy Holidays sign in the distance, with the shadow moving from simple blocks of pixels to something that is much clearer.
When moving from Ultra to Maximum settings we can also see the main difference in these settings, with object detail in the distance improving and higher resolution textures being used on the roads and buildings in the middle distance.
Tom Clancy's The Division PC Performance Review  Tom Clancy's The Division PC Performance Review  Tom Clancy's The Division PC Performance Review  Tom Clancy's The Division PC Performance Review  Tom Clancy's The Division PC Performance Review
At night we can see some of the most impressive visuals that The Division has to offer, with the reflections and lighting seen in the wet ground and in the snow being something unlike anything else I have ever seen in a game, especially is scenes where there is complex lighting or neon signs.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 Next»
09-03-2016, 12:33:58
Warchild
Im benching some results right now. I clearly see an issue with Gsync at the moment. Ill post some results when im done.
Look at the FPS loss with Gsync turned on with SLI. I thought SLI was fine until i started benching some results. I just kept it simple and consistent. Results are an average of 3 runs per variation. And this is with the new Nvidia drivers intended for The Division.
Using a ROG Swift Monitor with refresh set at 120hz via Nvidia panel. Interesting was that when using windowed mode in game, it automatically locked refresh to 60hz as opposed to the 120hz set by default.
http://i.imgur.com/mMZ7yIO.pngQuote
09-03-2016, 12:57:26
AngryGoldfish
Do you have actual 4k images uploaded anywhere I can view comparing the graphics settings? Either I'm missing something embarrassingly obvious or the images are far too small to actually compare.Quote
09-03-2016, 13:08:03
WYP
For whatever reason the 4K image links broke, but it it is fixed now.Quote
09-03-2016, 13:09:48
AngryGoldfish
Thanks!Quote
09-03-2016, 13:54:37
Treadpool
Noticed the 1440p benches are from beta, as noted in the screenshot title. Do you have updated benches for live? I have a 5930k (overclocked to 4.4) and a 980ti (also slightly overclocked) - with those settings I barely make mid 50s to 60 in-game. Especially with the NVAO+ stuff on. I don't see how you get 100 avg fps.Quote
