VTX3D HD7970 PCIE2 vs PCIE3 Review
Up Close
Published: 9th January 2012 | Source: VTX3D | Price: £439.99 |
Up Close
The packaging is a lovely golden colour and we have to say it's nice to see Ruby back again. Who doesn't want a spandex-clad dual-wielding busty girl on their package?
Accessories are pretty much what you'd expect the bridge and power convertor, but it's good to see that connectivity is covered with a DisplayPort to DVI and DisplayPort to HDMI adaptor, as well as a HDMI to DVI and DVI to VGA. No matter what screen you have to hand you'll be able to connect it to the VTX3D HD7970.
As for the card itself it's exactly what we'd expect a reference AMD card to look like. Lots of black plastic with some red go-faster stripes and the normal water-mill fan right up the end. Thankfully beneath that plastic shroud all is new with vapour-chambers and a redesigned heatsink. Hopefully the heat and noise issues that plagued the HD6970 have been solved.
Power is handled by 6 and 8pin PCIe connectors, so even as the high-end model this isn't a complete power hog. Indeed 'at the wall' the HD7970 draws around 200W when under load. Impressive.
By dropping their output options and moving them to the adaptors seen above, the vent is now the full width of the card which should help expel the heat easier than the small gap on the HD6970.
Very hit and miss as to the newer kit helping in any way. Some yes, some no. But I'd still be banking that the x79 pcie3.0 lane usage isn't being capitalised on by the mobo for anything other than storage, at this point - so Intel boast. Which isn't fair atm as the 7970 is pcie3.0 boasting on AMD's website.
Artificial benchmarking-wize, for the higher numbers you want for your submission, you'd stick with the "older" i7... which is bizarre. Verging on madness imo. Although I do recognize that there are bios upd8s for mobos, particularly Gigabyte I seen the other day, that are allowing higher oc etc. To that extent it's still a work in progress I guess.
Still bizarre to me. Newer cpu, newer mobo, quad memory - I'd expect more. Seems the realization is that the z77 (or whatever they'll be released as) will be the pci3.0 'real utilizers'. We will have to see.
On another note, I'd be interested in knowing if Mafia 2 and Metro 2033 were benched with PhysX used on the cards. I know it's classed as "unfair" to do so, by those who can't use it gpu-wize, but if you're looking at a set of results of which to base your purchase of a game to play either of them, and your £440+, you'd want to be sure you can enable everything and expect the same results. Especially when comparing with the older 580 @ £360+ Today.
Judging from the euphoric nature of the responses to 7970 reviews, I thought it cleared the 580 by more than it did in many graphs here. It certainly does an outstanding job of raising the minimum fps across the board, even in those it didn't get a better average fps in. A good die shrink, which I'm pretty sure is the best you can hope for from nVidia for a fair time to come.
Memory usage is something people don't closely look at. I can remember benching one rig with.. GTA X (not sure if 2/3 or whatever) and the graphics levels were not permitted to be raised any further, quality wize, cos the preferences showed that the graphics memory wouldn't take it. And this wasn't a cheap card, so memory can be important. It would be nice to see more games show such a memory usage bar in their preferences.
It's good to have a choice from both card manufacturers to chose from now, although I didn't think the 6970 was "that-bad" as people reported.Quote
