XFX 8400 GS 256mb
Test Setup notes
Published: 7th August 2007 | Source: XFX | Price: |
Test Setup
The setup is:
CPU: Intel Core2Duo E6700 @ 3.33Ghz
Motherboard: XFX 650i Ultra
RAM: 1gb Mushkin XP2-5300 4-4-4-12
Sound: Creative Labs X-Fi fatal1ty FPS
HDD: OS - 160gb Hitachi Deskstar SATA II
Power: Silverstone Zeus 560w
Case: Silverstone TJ09
Cooling: Scythe Infinity
As this card is a low end card I really don't have a whole lot to compare to (and the previous low end card setup was with an AMD 64 single core machine). However I will try to portray the card as best as I can using the target resolution of 1024 x 768 with 2 x AA.
I am using a manual run-through of the games listed, exactly the same as in previous reviews, but doing it slightly differently to get some consistant numbers. As stated above the target resolution is 1024 x 768 with 2 x AA. All synthetic benchmarks are at the stock resolution.
For installation I have installed the card as usual , checked that the card is seated correctly and powered on.
I am using a clean install of Windows XP Professional SP2 with all the latest patches.
nVidia drivers used were 162.18
The setup is:
Aye indeed. I think the card fits well in it's niche and really is great vfm
It's hard to look at a card like this when you're playing around with uber high end stuff all day but I think I gave it a fair shout and it performed well for it.
Hope y'all think it's a fair review
Quote
The card and packaging are as I expected. I`ve got 3 cards in this range previously (meaning below the x600), the 7300, 6500, 6200 (one of those may be wrong number) from XFX and they`ve pretty much been packaged as u`ve described. Box about the size of the card, low profile and the only difference being a passive old-skool looking sink. (which they seem to be implying the 8400 will have in the future)
I know this is around £30, but as time goes by it`ll push £20 as close as it can - especially around the dawn of the 98xx arrivals. There after u`ll catch them for less than £20. (I bought some of the above for £15-£18 pfft)
This card is what it is, as were the previous ones, I think we should appreciate that. It`ll work in a working desktop very well, a workhorse server type pc that u just basically want a display, and has the benefits of crossing to u`r htpc with some added kick.
£20-£30 - and knowing what u`r buying it for, they fill the gap for me. I am a little supprized it doesn`t play C&C a bit better, usually tho with this range of card u can get away with shutting everything down to minimum u can get away with it - but u have to appreciate that that is what u are doing.
Fits in the market well for me.Quote
