XFX 8800 GT XXX Alpha Dog Edition - G92 Performance
Test Setup and Notes
Published: 1st November 2007 | Source: XFX | Price: £210 |
Test Setup and notes
To test these high-end cards I set a PC that gives as little of a bottleneck as possible. The Test setup used for the cards is this:
CPU: Intel Core2Duo E6700 @ 3.33Ghz
Motherboard: XFX 650i Ultra
RAM: 2gb Mushkin XP2-6400 4-4-4-12
Sound: Creative Labs X-Fi fatal1ty FPS
HDD: OS - 160gb Hitachi Deskstar SATA II
HDD: Gaming - 2 x 40gb Hitachi Deskstars in RAID 0
Power: Silverstone Zeus 560w
Case: Silverstone TJ09
Cooling: Scythe Infinity
Games Tested:
DX9.0c
Call of Duty 2
F.E.A.R.
Oblivion
Quake 4
Command and Conquer 3: Tiberium Wars
Bioshock DX 9.0c path
I am using a manual run-through of the games listed, exactly the same as in previous reviews, but doing it slightly differently to get some consistant numbers. Notice that for all games I ran through with 4 x AA and 8 x AF @ 1920 x 1200. For all of the 3Dmark benchmarks I did two runs. One run was with the stock settings that the free version of the benchmark comes with and one was with 4 x AA @ 1920 x 1200.
For installation I have installed the card as usual with the normal PCI-E power dongle. Checked that the card is seated correctly and powered on.
I am using a clean install of Windows XP Professional SP2 with all the latest patches.
The 8800GT XXX Alpha Dog Edition card used the nVidia 169.02 Forceware drivers.
Note that the two Ultra cards were tested earlier using 173.71 drivers
The ATI card was installed with the Catalyst Control Center 7.9's.
DX10 Comparison Setup
UT3 Beta
Crysis
Bioshock
Testing was performed on a clean install of Vista, with the 169.02 drivers.
Cards
XFX 8800 GT. Core Speed: 670. Memory Speed: 1950 (975). Stream Processor Clock: 1650MHz.
XFX 8800 Ultra "Extreme" Edition. Core Speed: 650. Memory speeds: 2200 (1100). Stream processor clock: 1650MHz.
XFX 8800GTS 320mb "Fatal1ty" Edition. Core Speed: 650. Memory speeds: 2000 (1000). Stream processor clock: 1500MHz.
Gainward 8800 Ultra. Core Speed: 612. Memory Speed 900 (1800). Stream processor clock 1500MHz
MSI 8800 GTX. Core Speed: 575. Memory speeds: 2200 (1100). Stream processor clock: 1350MHz.
Sapphire HD 2900 XT. Core Speed 740. memory speed 1650 (825). Stream processor clock 320MHz.
Overclocking on the nVidia cards was performed using RivaTuner, and the Nvidia control panel using nTune for the 8800GT.
Overclocking on the ATI card was performed using AMD GPU Overclocking Tool.
Games Tested:
DX9.0c
Call of Duty 2
F.E.A.R.
Oblivion
Quake 4
UT3 Beta
Crysis
Bioshock
Cards
Clear your cache mate, it's 92%Quote
Brilliant write up none the less Kemp!Quote
Lovely review Kempez
Quote
Nice review........that's one of the cards I'm currently looking at getting......
One small question for you all though, with those 2 sets of mounting holes around the core, what type of GPU water blocks will fit w/wo adapter plates/fittings????? Just wondering if my current Swiftech MCW60 will fit without having to get any sort of adapters.Quote
I am guessing the 10% is an error... :eh:
Loving thing review Kemp, Well done mate.Quote
