XFX 8800 GTS 512 and Asus 8800 GT 512 - G92 shoot out
Test Setup
Published: 24th December 2007 | Source: Asus and XFX | Price: £225-£235 and £156-£177 |
Test Setup
As you may be aware, Overclock3D has recently added to it's benchmarking setup to make sure that we cover the increasing trend for Quad Core. With this in mind, our Test Setup is as follows:
Intel Core2Quad Q6600 @ 3.6GHz
Hitachi 7K160 HDD
Samsung DVD-RW
Please note that we have set the overclock on the Q6600 to be able to keep our test setup fairly consistent as the speeds of CPU's increase in the near future.
Benchmarks Used
Again, Overclock3D has revised it's benchmark setup to really test the new DX10 GPU's, while still including some old favourites in there:
Synthetic Benchmarks
Please note all Synthetic benchmarks were run at stock settings; just as the free ones would be, as well as 1920 x 1200, with 4 x AA added. All benchmarks are repeated three times for consistency.
FutureMark 3DMark03
FutureMark 3DMark05
FutureMark 3DMark06
Gaming Benchmarks
All gaming benchmarks are run through at a demanding stage of the game with no savepoints to affect FPS. These are manual run-though's approximating 3 minutes and all gaming benchmarks are run three times through the same points for consistency. We hope that this gives an accurate and interesting depiction of "real-life" gaming situations. Note the resolutions and AA each game was run at.
All gaming tests were performed in Windows Vista Ultimate, under DX10 if available.
Call of Duty 4 - 1920 x 1200, 4 x AA set in-game
Oblivion - 1920 x 1200, 4 x AA set in drivers and HDR set on in-game. Settings on "Ultra"
F.E.A.R. - 1920 x 1200, 4 x AA set in game, soft shadows enabled
Bioshock - 1920 x 1200, all settings to maximum in-game
Unreal Tournament 3 - all settings set to maximum in-game
Company of Heroes - DirectX10 patch. 1920 x 1200 with in game settings as here.
Crysis - 1680 x 1050, all in-game settings set to "High"
Again, all game run-through's are repeated three times for consistency and accuracy.
We hope that this represents a good band of games and benchmarks for people wanting a performance overview of gaming at this current time.
Cards tested
Here are the cards tested in the benchmarking:
Asus 8800 GT Top Edition. GPU: 700Mhz. Memory: 1000MHz (2000MHz). Stream processor clock: 1650MHz
XFX 8800 GTS 512 XXX Alpha Dog Edition. GPU: 678Mhz. Memory: 986 (1972MHz). Stream processor clock: 1650MHz.
Powercolor HD3850. GPU: 720Mhz. Memory: 900MHz (1800MHz). Stream processor clock: 690Mhz.
MSI 8800GTX. GPU: 575Mhz. Memory: 900 (1800). Stream processor clock: 1350MHz.
Note that we did have an 8800 GTS in for testing but unfortunately there was a hardware issue with the card and as such we could not include the results from this card.
Overclocking of all of the Nvidia cards tested was performed in the Nvidia drivers using the Ntune add-on.
Nvidia drivers used in the testing were ForceWare Release 169 WHQL and ATI drivers were ATI Catalyst™ 7.12 Display Driver for Windows Vista (32 bit)
Thing is though there is a BIOS voltmod for the 8800GT that GREATLY increases its overclockability. If there isn't one for the 8800GTS I see them both reaching high limits but so far the 8800GT seems to OC better. With good cooling and the volt mod this thing easily passes 800mhz core, I've seen some at 850+.
What you also go to look at as well is shaders, they seem to be the key thing atm if the shaders OC much better on the 8800GT, which I guess they kinda should since they could simply lock the worst performing ones to get it top out better, it could impact performance in certain titles a lot.
Nice review though I was surprised the 8800GT didn't clock more, there wasn't a heat issue was there?
It should also be said about the supposed problems of the memory modules on the 8800GT, seems that long term use of the memory at 2ghz+ and it brakes. Thats why some companies like Zotac use better memory modules for their cards.Quote
Great review Kempez, can't wait to open my GTS tomorrow
Quote
The GT was a little hot yes, but I will never change the cooling or take off the heatsink prior to running any tests. I test every card as it would be when it appears on your doorstep
Volt-modding is not part of the overclocking testing as the percentage of users who do that is small and it voids any warranty you have.
An overclock is dependent on what RAM is used, what cooling is like and also what luck you get with the silicon...the overclocking gods didn't smile on me this time
@Rast: I agree, the ATI card is a great card as I said in the ATI review, but this review was for these two cards. Having said that: would I buy the HD3850 personally? No, I'd go for an 8800 GTS 512mb G92 or an 8800 GT 512 G92
It's simply not fast enough with every game, I'm afraid.Quote
I have to be fair, even tho u`ve got a 1 to 4 positioning, I don`t think there`s that much in it for any of them. I know the Ati slides in the rankings, but it does show itself to be a fine card.
An interesting comparison would have been performance versus costing, seeing as they`re as close as they appear to be.
I`m a bit at odds with the oc results too. I simply can`t achieve the memory overclock on my GT without it having fits. But I can clock the gpu to around 720 (from 670).
What would impress me is some1 buying the cheapest GT, putting it under water, and claiming back those clock hertz with their superior cooling. Sounds nice.
Suprizes me a bit tho that the GTS isn`t launched as a bigger performer. Although pricewize, it does seem to start from stock where the GT limit starts. Leaving u further to climb
Nice review m8, think every1s doing the "going to bed early to get up early" trick
