XFX 8800 GTS 512 and Asus 8800 GT 512 - G92 shoot out
Synthetic benchmarks - 3DMark
Published: 24th December 2007 | Source: Asus and XFX | Price: £225-£235 and £156-£177 |
FutureMark - 3DMark03
3DMark03 is a benchmark that uses mainly a DirectX 8 featureset including several pixel fillrate tests. I included this test in the review to see an approximation of how well old games will play on the current gen cards, as well as how well each card copes with the fillrate tests.
Here we can see that surprisingly the Asus 8800 GT does very well at the lower resolution and both G92 parts beat the 8800 GTX tested.When the resolution was upped, the 8800 GT comes out 2nd again with the bigger brother, the 8800 GTX taking the win.
FutureMark 3DMark05
3DMark05 is a benchmark based on DirectX 9 with more advanced shading and bump-mapping techniques, as well as a tough CPU test integrated.
Here again the G92 parts outpace the 8800 GTX G80 part in both benchmarks. We see that the 8800 GTS is only just quicker in these tests.
FutureMark - 3DMark06
3DMark06 is a more complex 3D benchmark, using many of the more advanced techniques found in DirectX 9.0c such as utilising Shader Model 3.0 and HDR lighting to create a tough benchmark that stresses the GPU and CPU.
Here we see a similar result with the XFX 8800 GTS just about stepping ahead of the Asus 8800 GT, but not by much. The 8800 GTX is a little off the pace here again.
Thing is though there is a BIOS voltmod for the 8800GT that GREATLY increases its overclockability. If there isn't one for the 8800GTS I see them both reaching high limits but so far the 8800GT seems to OC better. With good cooling and the volt mod this thing easily passes 800mhz core, I've seen some at 850+.
What you also go to look at as well is shaders, they seem to be the key thing atm if the shaders OC much better on the 8800GT, which I guess they kinda should since they could simply lock the worst performing ones to get it top out better, it could impact performance in certain titles a lot.
Nice review though I was surprised the 8800GT didn't clock more, there wasn't a heat issue was there?
It should also be said about the supposed problems of the memory modules on the 8800GT, seems that long term use of the memory at 2ghz+ and it brakes. Thats why some companies like Zotac use better memory modules for their cards.Quote
Great review Kempez, can't wait to open my GTS tomorrow
Quote
The GT was a little hot yes, but I will never change the cooling or take off the heatsink prior to running any tests. I test every card as it would be when it appears on your doorstep
Volt-modding is not part of the overclocking testing as the percentage of users who do that is small and it voids any warranty you have.
An overclock is dependent on what RAM is used, what cooling is like and also what luck you get with the silicon...the overclocking gods didn't smile on me this time
@Rast: I agree, the ATI card is a great card as I said in the ATI review, but this review was for these two cards. Having said that: would I buy the HD3850 personally? No, I'd go for an 8800 GTS 512mb G92 or an 8800 GT 512 G92
It's simply not fast enough with every game, I'm afraid.Quote
I have to be fair, even tho u`ve got a 1 to 4 positioning, I don`t think there`s that much in it for any of them. I know the Ati slides in the rankings, but it does show itself to be a fine card.
An interesting comparison would have been performance versus costing, seeing as they`re as close as they appear to be.
I`m a bit at odds with the oc results too. I simply can`t achieve the memory overclock on my GT without it having fits. But I can clock the gpu to around 720 (from 670).
What would impress me is some1 buying the cheapest GT, putting it under water, and claiming back those clock hertz with their superior cooling. Sounds nice.
Suprizes me a bit tho that the GTS isn`t launched as a bigger performer. Although pricewize, it does seem to start from stock where the GT limit starts. Leaving u further to climb
Nice review m8, think every1s doing the "going to bed early to get up early" trick
