XFX 8800 GTS 512 and Asus 8800 GT 512 - G92 shoot out
Call of Duty 4, F.E.A.R. and Bioshock
Call of Duty 4
Call of Duty 4 is a stunning DirectX 9.0c based game that really looks awesome and has a very full featureset. With lots of advanced lighting, smoke and water effects, the game has excellent explosions and is fast and furious, perfect for our test suite.
call of duty 4
As you can see here, the 8800 GTS tops the pile in terms of highest FPS, but had a few slight dips in FPS at points. The 8800 GTX showed a more smooth overall performance through testing but, in all honesty there wasn't a whole lot to pick between any of the 8800 series cards and even the HD3850 kept up with the pace.
F.E.A.R.
F.E.A.R. is a game based on the Lithtech Jupiter EX engine. It has volumetric lighting, soft shadows, parallax mapping and particle effects. This is a fairly old game but was a very testing one at the time of release and still looks fantastic, so we've kept it in.
F.E.A.R.
F.E.A.R. always produces slightly odd results if you look at the fine details. However, as an overview, the XFX 8800 GTS was the best performer with the 8800 GTX and Asus 8800 GT not too far behind. All cards ran F.E.A.R. with no problem at all.
Bioshock
Bioshock is a game based on the Unreal Engine 3. It uses some DirectX10 features such as awesome water and smoke effects. The detail level in the game, combined with a frantic pace makes for an excellent benchmark.
Bioshock
Bioshock again shows the trend for the GTS and the GT to be very quick. The 8800 GTX had a little "blip" in this game and I couldn't for the life of me figure out why it's results weren't as good as the other two 8 series cards, even after many repeat runs. Still, every card was smooth as butter in this game at this resolution.
«Prev 1 2 3 4 5 6 7 8 9 10 Next»
24-12-2007, 22:24:49
Rastalovich
Great insight into the higher end of the gpu spectrum.
I have to be fair, even tho u`ve got a 1 to 4 positioning, I don`t think there`s that much in it for any of them. I know the Ati slides in the rankings, but it does show itself to be a fine card.
An interesting comparison would have been performance versus costing, seeing as they`re as close as they appear to be.
I`m a bit at odds with the oc results too. I simply can`t achieve the memory overclock on my GT without it having fits. But I can clock the gpu to around 720 (from 670).
What would impress me is some1 buying the cheapest GT, putting it under water, and claiming back those clock hertz with their superior cooling. Sounds nice.
Suprizes me a bit tho that the GTS isn`t launched as a bigger performer. Although pricewize, it does seem to start from stock where the GT limit starts. Leaving u further to climb
Nice review m8, think every1s doing the "going to bed early to get up early" trick Quote
24-12-2007, 22:25:40
Hyper
Nice to see this review is finally up
Shame I cant view it as 128k is painfully slow :sleep:Quote
24-12-2007, 23:07:43
Hatman
Thing is though there is a BIOS voltmod for the 8800GT that GREATLY increases its overclockability. If there isn't one for the 8800GTS I see them both reaching high limits but so far the 8800GT seems to OC better. With good cooling and the volt mod this thing easily passes 800mhz core, I've seen some at 850+.
What you also go to look at as well is shaders, they seem to be the key thing atm if the shaders OC much better on the 8800GT, which I guess they kinda should since they could simply lock the worst performing ones to get it top out better, it could impact performance in certain titles a lot.
Nice review though I was surprised the 8800GT didn't clock more, there wasn't a heat issue was there?
It should also be said about the supposed problems of the memory modules on the 8800GT, seems that long term use of the memory at 2ghz+ and it brakes. Thats why some companies like Zotac use better memory modules for their cards.Quote
24-12-2007, 23:29:40
Brooksie
Great review Kempez, can't wait to open my GTS tomorrow Quote
24-12-2007, 23:34:22
FarFarAway
The GT was a little hot yes, but I will never change the cooling or take off the heatsink prior to running any tests. I test every card as it would be when it appears on your doorstep
Volt-modding is not part of the overclocking testing as the percentage of users who do that is small and it voids any warranty you have.
An overclock is dependent on what RAM is used, what cooling is like and also what luck you get with the silicon...the overclocking gods didn't smile on me this time
@Rast: I agree, the ATI card is a great card as I said in the ATI review, but this review was for these two cards. Having said that: would I buy the HD3850 personally? No, I'd go for an 8800 GTS 512mb G92 or an 8800 GT 512 G92 It's simply not fast enough with every game, I'm afraid.Quote
