XFX GTX295 PCIe Graphics Card
Unreal Tournament 3 is the highly anticipated game from Epic Games and Midway. The game uses the latest Unreal engine, which combines fast gameplay along with high quality textures and lighting effects. All benchmarks were performed using UTbench with a fly-by of the DM-BioHazard map. As usual, all benchmarks were performed 5 times, with the highest and lowest results being removed and an average calculated from the remaining three.
GRID
Race Driver: Grid is a visually taxing game that presents a challenge to any graphics system. Results were recorded using FRAPS to log the average FPS over a 2 minute race. To ensure consistency, the same track, car and general path of travel was used in each of the 5 benchmark runs for each graphics card, with an average FPS being calculated from the median three results.
Call of Duty 4 is a stunning DirectX 9.0c based game that really looks awesome and has a very full feature set. With lots of advanced lighting, smoke and water effects, the game has excellent explosions along with fast game play. Using the in-built Call Of Duty features, a 10-minute long game play demo was recorded and replayed on each of the GPU’s using the /timedemo command a total of 5 times. The highest and lowest FPS results were then removed, with an average being calculated from the remaining 3 results.
Results Analysis
Much the same story was to be had with our first run of benchmarks. All the games above, even the PhysX enabled UTIII favoured the 4870×2, that was until the resolution was increased and AA applied. This is when the GTX295 took hold of the 4870×2 and gave it a solid beating. Thus far we are starting to see a pattern of results that show the GTX295 performing better as the resolution is increased, surprisingly, in spite of it having less memory available than the 4870×2.
Let’s move on..
