XFX GTX 260 XXX SLI Performance
Test Setup & Overclocking
Test Setup
As we will be testing the GTX260 in both single and dual (SLI) configurations we decided to use the 790i Ultra motherboard utilizing DDR3 modules to ensure that bandwidth of the memory would not be cause for throttling the results. Both ATI and NVidia setups were configured to be as balanced as possible and to give a true representation of each of the graphics cards capabilities.
A selection of games and benchmark suites has also been chosen to test each of the cards with several game engines. Each of the cards will be run at both low and high resolutions with varying levels of texture filtering to represent the use of the card with both small and large screen sizes.
3DMark05
1024x768 / 0xAA / 0xAF (Default)
1920x1200 / 4xAA / Optimal
3DMark 06
1280x1024 / 0xAA / 0xAF
3DMark Vantage
1280x1024 / Performance Mode
1900x1200 / Extreme Mode
Quake4
1280x1024 / Ultra / 4xAA / 4xAF
1920x1200 / Ultra / 4xAA / 4xAF
Race Driver: GRID
1280x1024 / DX10 / Max/4xAA
1920x1200 / DX10 / Max/4xAA
Call of Duty 4
1280x1024 / Max / 4xAA
1920x1200 / Max / 4xAA
F.E.A.R
BIOSHOCK
1280x1024 / DX10 / High
1920x1200 / DX10 / High
Crysis
1280x1024 / DX10 / V.High / 4xAA
1920x1200 / DX10 / V.High / 4xAA
A new entry into our lineup of games is the very popular racing Arcade/Sim Racer Driver:Grid from Codemasters. At OC3D we like to test our GPU's on review with as many current graphics engines as possible and as we don't currently have a simulator in our line up and due to the popularity of this game it only seemed right that it was included in our series of benchmarks.
To judge how well the GTX260 performs, we will be pitching it against the much loved HD4870 from ATI. While the XFX GTX260(s) in our possession will be tested in the stock (factory overclocked) state it should be noted that the ATI card(s) are stock clocked. Apart from the usual FPS results, we like to give you, the reader, an accurate representation of what you are getting for your hard earned cash so along with the FPS results we will also be including Price/performance charts.
Overclocking
Never ones to be satisfied with any given clockspeed we attempted to push the already overclocked XFX GTX260 a little further and are pleased to report that we managed and extra 34mhz on the core (99mhz over stock) and 41mhz on the memory clock. Any further clocking resulting in tearing and artifacts but considering the card is already overclocked, any extra is a bonus.
To test the cards stability we ran a full suite of Futuremark Vantage which gave us an extra 500 points over factory clock settings. I decided to have a little 'extra' playtime with the GTX260's and ran a 'max overclock' run, clocking the CPU upto 4.25ghz and added the physx driver to see how far the GTX260's could go :
Vantage
Not a bad showing at all but the result is massively influenced by the CPU overclock and obviously the PhysX driver so the standard official Geforce driver alone will be used for the benchmarks. Still, it goes to show that, with the right setup and even on air cooling, some great benchmark results are possible with the XFX GTX260 XXX cards!
«Prev 1 2 3 4 5 6 7 8 Next»
09-12-2008, 16:35:01
AndrewDrinnan
I just dont understand why the XFX GTX260 XXX is £20 more than the XFX GTX260 Black Edition even thought the Black has higher clocks. Hmmm... WeirdQuote
09-12-2008, 16:55:48
Rastalovich
Well this was taken over 4 months ago, so things may well have changed a bit.
It is interesting to me that with more-or-less the same setup with the 2 mid range 260 cards switched out for the 280, the stock 280 3dmarks make the decision of 1 card vS 2 a very simple one.
Also shoddy to reflect that XFX use exactly the same packaging on the 280 as with the 260, even down to forgeting a 8pin pcie adapter.
Holy thread revival !Quote
09-12-2008, 17:00:37
AndrewDrinnan
Was it that long ago? Ooops my bad for not checking the date.Quote
