XFX Radeon 5750 XXX Review
Test Setup and Overclocking
Test Setup
Naturally when reviewing a graphics card it's important that the subsystem doesn't inhibit the performance possibility of the card. For this reason we're using a P55 based system with our Intel i7 870 running at 4GHz to make sure the 5750 XXX never wants for information to process.
CPU : Intel i7 870 @ 4GHz
RAM : G.Skill Trident 2000MHz CL9 4GB
PSU : Cougar 1000CM
HDD : Samsung Spinpoint 1TB
Motherboard : MSI P55-GD85
OS : Windows 7 64
Cooling : Thermalright MUX-120 with Arctic Cooling MX-3
Our tests will be run in the usual OC3D manner with them being performed 5 times, the fastest and slowest discarded then an average of the remainder taken. Although this is a pre-overclocked card we're also running the tests in the "out the box" and overclocked states.
The XFX HD5750 XXX is factory overclocked by 40MHz on the GPU core, and 50MHz on the GDDR5 when compared to the standard XFX HD5750. Whilst this isn't a paultry gain as always we love to push things a little harder to see what performance is available.
XFX Radeon 5750 XXX Stock Core Clock Speed
Using the ATI Overdrive feature available as part of the Catalyst Control Centre, we gradually increased the settings, checking for artifacts and temperatures all the time. The best stable overclock we managed was 60MHz extra on the RAM and 65MHz extra on the GPU. Temperatures were still well within tolerances but 815MHz or higher started to get artifacts or make the graphics driver crash, so we throttled back to 805MHz which ran perfectly stable and it was at this speed that our tests were run.
One thing to notice is that we, as always, pushed the fan to the maximum to ensure temperature isn't an issue whilst overclocking and the moment you get past 50% on the fan it sounds like a hurricane. 100% is utterly intolerable and was audible in the other room akin to someone vacuuming.
XFX Radeon 5750 XXX Overclocked and Overclocking Potential
With our overclocking out the way and the rig set up, let's get on to some results.
«Prev 1 2 3 4 5 6 Next»
