XFX RX590 Fatboy Review
Next up in our brace of RX 590 reviews is the XFX RX 590 Fatboy.
We’re struggling to think of a card that has come with such a strange name. It would be like calling a card a lard arse. However, names are temporary and forgettable, as long as the performance is there nobody will give two hoots about its subtitle. We did prefer the Dual Dissipation name of old XFX cards though.
So far we’ve seen that the RX 590 is a bit better than the RX 580 and the GTX 1060, giving performance akin to a theoretical GTX 1065. How does the XFX take upon this new Radeon card compare to the PowerColor Red Devil version? Let’s find out.
Technical Specifications
As you can see, the RX 590 is largely a faster version of the RX 580, with the reduction in process from the 14nm of the old RX 580 to the smaller 12nm of the RX 590 enabling higher clock speeds and more power to be fed to the card. Like the PowerColor the XFX Fatboy comes equipped with a factory overclock.
  Radeon RX 590 Radeon RX 580
GCN Architecture 4th Generation 4th Generation
Manufacturing Process 12nm FinFET 14nm FinFET
Die Size 232 mm2 232 mm2
Compute Units 36 36
Stream Processors 2304 2304
Clock Speed (Boost/Base) 1545 MHz/1469 MHz 1340 MHz/1257 MHz
Compute Performance 7.1 TFLOPS 6.17 TFLOPS
Texture Units 144 144
Texture Fill Rate 222.4 GT/s 190 GT/s
ROPs 32 32
Pixel Fill Rate 49.5 GP/s 42.9 GP/s
Memory Size 8 GB 8 GB
Memory Bandwidth 256 GB/s 256 GB/s
Memory Interface 256 bit 256 bit
Memory Type GDDR5 GDDR5
Board Power 225W 185W
Freesync Support Yes Yes
DirectX 12 Support Yes Yes
Vulkan Support Yes Yes
Display Port Version 1.3 HBR/1.4 HDR 1.3 HBR/1.4 HDR
