XFX Speedster RX 6800 XT MERC319 Review
Borderlands 3
Published: 25th November 2020 | Source: XFX | Price: |
Borderlands 3
Borderlands 3 saw Gearbox Software return to developing their most famous IP following the somewhat dubious reception The Pre Sequel received. Borderlands has plenty of settings to tweak and, despite looking superficially similar to Borderlands 2, it’s significantly more demanding upon your hardware. At higher resolutions only the most performance rich need apply. Naturally we run with everything at the maximum possible settings.
And they're so expensive. I didn't think there would be such a high premium over reference. They perform better, but I don't know if I would want to shell out another £100 for that extra bit of performance.
Same with every decent aftermarket card though
Gorgeous card. Then you see the back plate
![]() What a shame. I suppose you could vert mount it. |
I like it tbhQuote
I like it tbh |
I actually like this one which is weird considering the Merc sprawling across it is not my usual cup of tea.Quote
https://i.imgur.com/FyNdrRq.pngQuote
