ASUS ROG Gladius II Gaming Mouse Review
Software
Published: 28th March 2017 | Source: ASUS | Price: |
Software
The Armoury software is quick to install and easy to use, with every feature and customisation option clearly labelled and responsive. We'd like it to remember our settings in one go before having to save it, rather than the current methodology wherein every adjustment has to be saved before you make the next one else it forgets. We're sure this can be achieved in an update and look forward to this minor issue on an otherwise excellent software package being fixed. As you can see from the third screenshot the sensor at the heart of the Gladius II has a huge range available so that even the most demanding user can achieve a setting that suits both them and their current game of choice.
You need the Spatha thenQuote
If it was $50-100 cheaper then i would put it on my list.
I was thinking about going old school and using a trackball mouse lolQuote
