ASUS Strix Mouse, Headset & Keyboard Review
Strix Pro Headset Up Close cont
Published: 24th September 2014 | Source: ASUS | Price: |
Pro Headset
As well as the regular 3.5mm jack the Strix Pro comes equipped with three cables to ensure maximum compatibility. There is the remote/breakout-USB for the PC, one for any old phones you might have, and one for pretty much everything else that is modern, including the PS4.
The remote volume is nice and compact, whilst having enough weight to ensure it doesn't fall over when you're groping for it in the heat of battle. There is a tendency for ones this small to be able to be turned by the twist of the cable, but the ASUS Strix Pro volume weighs enough that this hasn't been an issue.
The braiding is nice and tight whilst being flexible and smooth to the touch. Very good quality indeed. Even the USB plug has been sculpted to match the angular Strix Pro design. At the very least this makes it easy to spot amongst the sea of black USB plugs on the dark side of your tower.
