CM Storm Sentinel III Review
Software and Lighting
The software probably has the biggest improvement from its predecessor. Everything looks far more modern and within easy reach. If we had a quibble it’s that the light grey on dark grey text isn’t exactly the most obvious. Sure it looks nice but we’ll always take contrast over peering intently to see what we’re doing.
There are a couple of personalisation options. You can adjust the lighting to a hue and mode of your choice, although we couldn’t find a way to have separate colours on the headlights and the palm portion. It appears that one is all you get. You can change the logo on the display to anything you wish, so long as you have a bitmap image of it.
CM Storm Sentinel III Review     CM Storm Sentinel III Review
Lighting
CM Storm Sentinel III Review     CM Storm Sentinel III Review Â
