Coolermaster Mastermouse MM520 and MM530 Review
When the CM Storm arm of Coolermaster was still around they produced a massive amount of affordable mice covering a wide variety of designs.
Since then CM Storm has disappeared from the radar and Coolermaster have moved into a series of peripherals labelled Masterx. We’ve reviewed the Masterpulse headsets, Masterkeys keyboards, and even some Mastermouse Pro mice. Today we have two mice that follow on from the affordable nature of the CM Storm products of yore, whilst still being bang up to date with their feature set.
Both are similar enough in their specifications that we’re reviewing them together, so let’s take a look at the Mastermouse MM520 and Mastermouse MM530.
Technical Specifications
The MM520 and MM530 are very tightly matched in specifications with just the extra button on the MM530 due to its palm based design. The MM520 reminds us in design terms of the old Xornet we liked so much whilst the MM530 follows the regular slightly-right-handed-but-not design that doesn’t quite match up to full ambidextrous but could still be usable by a left handed person.
Both have a very beefy sensor, particularly given their affordable cost, with the PixArt 3360 supporting up to 12000 DPI at 50G acceleration, easy to obtain when the mice only weight 132 including cable.
  MM520 MM530
Sensor PixArt 3360 PixArt 3360
DPI Presets 400/1200/4000/12000 400/1200/4000/12000
Acceleration 50G 50G
Weight 132g 132g
Design Right handed Right handed
Grip Claw Palm/Claw
Material PBT Buttons and Middle PBT Buttons and Middle
Rubberised sides Yes Yes
Switches Omron 20m Omron 20m
Buttons 6 7
Lighting RGB RGB
MSRP 49.99 Eur 49.99 Eur
