Corsair K70 RGB Pro
iCUE Software
Corsair K70 RGB Pro
iCUE Software
As anyone who has used a Corsair product can attest their iCUE software is up there with the best. Powerful enough to handle some very complicated setups, yet (largely) simple enough to use if you just want to change the colour of your keys. With the AXON processing at the heart of the K70 RGB Pro you can push the polling rate up to 8000Hz if you wish, as well as all the macro and complex lighting effects that we have come to expect from Corsair.
Corsair K70 RGB Pro
Corsair K70 RGB Pro
Corsair K70 RGB Pro
Corsair K70 RGB Pro
Corsair K70 RGB Pro
Corsair K70 RGB Pro
«Prev 1 2 3 4 5 Next»
06-05-2022, 05:50:36
Peace Ð
I have the K100 and while it's definitely better than my Logitech G910, I will never get a manufacturer's own switch design again... The Logitech sounded cheap, the Corsair sounds cheap and takes a LOT of time to get used to.
The wrist rest is nice, but it can actually block the lower numpad keys so they get stuck under it -.- stupid...
The RGB is nice, though.Quote
