Glorious Forge Pro Golden Panda Wireless Review
Core Software
We cannot praise the software highly enough. It’s so easy to read and well laid out. Clear and obvious were the watchwords and it shows.
It’s not often you find software that is as clearly laid out as the Glorious Core. Everything where you’d expect it to be and it’s easily the most responsive control package we’ve seen.
Configuring the buttons to do your bidding is incredibly easy, and there are loads of presets built in to the Core software, as well as a powerful Macro editor if you really want to get down and dirty.
