Logitech G900 Chaos Spectrum Review
Software
The Logitech Gaming software supports all their hardware from one download. It does mean that the software is a fairly hefty download, but once in use it’s responsive and easy to find what you’re after. Worth paying particular attention to is the top right image where you can see the option to pick which button arrangement you’re using. The battery charge indicator is clear and has the option of flagging up an on-screen overlay should the charge drop whilst you’re in the middle of a frantic session. Frustratingly the only two colour options are cycle, which is fine for showing off but not much use if you want clan colours, or single colour breathing. If there is a static colour option we couldn’t find it.
Logitech G900 Chaos Spectrum Review     Logitech G900 Chaos Spectrum Review
Logitech G900 Chaos Spectrum Review     Logitech G900 Chaos Spectrum Review Â
