Mad Catz R.A.T 8+ Adv Gaming Mouse Review
Up Close - Adjustability
Published: 28th August 2020 | Source: Mad Catz | Price: |
Even without the weights the R.A.T 8+ Adv isn't the lightest mouse on the market, but if you prefer something with a little more junk in the trunk then it definitely will keep you happy, and the three weights are easy to remove by unscrewing the spring at the back. It's a very easy mouse to tune to your liking.
There are three different palm rests included with the R.A.T 8+ Adv and they are all capable of sitting very far back as well as abutting the middle of the mouse.
The textured one...
And a taller one for those of you who have more of a claw style grip.
There are three side panels if you include the default one. Thanks to some carefully designed mounting holes and pins they are easy to locate and lock in place before screwing them in using the included hex key.
One that matches the left hand side 'shelf' setup.
And a textured one to match the palm rest.
I had one of the earlier models of this mouse. Can't remember which one exactly. I loved everything about it. Customisation, adjustability, looks.
Sadly it packed up shortly after the warranty ended. I paid a lot of money for it and was extremely happy with my purchase until it died. Should have lasted much longer for the price. I'm on my second roccat tyon. 1st one didn't die but I had some double clicking. Common issue with this model. Got 2nd one for 29.99 on Black Friday. I wish it was a little bit smaller. |
I've had 2 of these older models, both of them were really nice in shape, but the internal hardware was crap, esp the mouse switches which for both of mine went bad and one click ended up in being a double click, which is impossible to work with.Quote
I'm on my second roccat tyon. 1st one didn't die but I had some double clicking. Common issue with this model. Got 2nd one for 29.99 on Black Friday. I wish it was a little bit smaller.Quote
