Razer Deathadder Elite and Gigantus Mousepad Review
Up Close - Gigantus
Up Close - Gigantus
Mouse pads are easily the simplest thing we review here at OC3D. The Gigantus is a, ahem, gigantic cloth surface. There is plenty of padding for your wrist if you're a palm type gamer, yet it never gets squishy. The surface itself is excellent quality and guarantees smooth tracking regardless of your sensor settings. The underside has Razer's searing green hue on an extremely grippy rubber pack. The combination of this high friction underside and the raw size of the Gigantus ensure that it never budges no matter how hard you try.
Razer Gigantus Mousepad Size
Razer Gigantus Mousepad Surface
«Prev 1 2 3 4 5 6 Next»
29-12-2016, 12:47:45
dabar_šolta
i think point of more dpi is similar to anti-aliasing,maybe way overkill but why not when there is technology available.
on picture should be circle motion , from A to B is high dpi ,from B to C and from C to D is 5x lower dpi so all fine movement in between is lost.Quote
29-12-2016, 13:26:23
Nelis
Using the deathadder chroma. I turned down the dpi to 1500. Any higher and it feels like i have a muscle cramp. The mouse flying over the screen like roadrunner. Seeing al these really high dpi mice nowadays I have a hard imagine what the dickens you need or use it for. But I am a old fart is propably the reason whyQuote
29-12-2016, 19:49:08
jimma47
I had my DeathAdder (3.5 IIRC?) turned down also.
I think it's basically aimed at marketing - Highest number wins. I'm sure there are people out there that can and will use those settings but it's certainly not average old me.Quote
29-12-2016, 21:11:22
Dicehunter
Nothing to do with being older, I've been using a max of 1000DPI since I started gaming on PC when I was 15, 15 years ago.
I've never seen the attraction of super high DPI, It makes aiming much harder.Quote
30-12-2016, 03:23:33
Dawelio
I wonder how high/what DPI professional gamers use? Like FPS professionals etc?...Quote
