Roccat Ryos MK FX Mechanical RGB Gaming Keyboard Review
Software
The Roccat software is a pretty hefty package and despite downloading the latest driver version from the website still required two updates before it was happy to see the Ryos MK FX plugged into our test system. The ‘start page’ is one you can pin your own oft-used elements to but it defaults to having everything, which is hardly a calm beginning for the user. Once you move away from that into the individual sections it all becomes a lot clearer and easier to use. Lighting is probably the area that most people will want to tweak and it’s great that Roccat have provided a lot of presets as well as preset key clusters so that you can swiftly highlight elements of the keyboard for whichever game you’re running.
Roccat Ryos MK FX Mechanical RGB Gaming Keyboard Review     Roccat Ryos MK FX Mechanical RGB Gaming Keyboard Review
Roccat Ryos MK FX Mechanical RGB Gaming Keyboard Review     Roccat Ryos MK FX Mechanical RGB Gaming Keyboard Review Â
