Roccat Skeltr Smart Communication RGB Gaming Keyboard Review
Software
The Roccat software is a bit of a pain to get up and running because it is a one-stop shop for your Roccat peripherals, so you need to install the software, then install the relevant hardware support, then usually there is a firmware upgrade for that, and the Roccat Swarm element comes as a separate package too. With the initial installation procedure out of the way though you end up with a gorgeous looking piece of software, with everything well laid out, easy to see and performs as responsively as you would hope. There are plenty of pre-built macro packages for some of the most popular titles too, so you can be up and running quickly.
