Corsair Dominator GT 1600MHz AM3 Review
Packaging & Initial Impressions
Published: 2nd July 2010 | Source: Corsair | Price: £160.58 |
The Corsair Dominator GT 1600 comes packaged in a fairly standard plastic outer shell. For those (like me) who regularly need treatment from stab wounds while trying to open packaging such as this, you're in luck as this particular set opens with ease.
This particular lineup of memory sports a stylish black and red colour scheme and tall heatsinks to boot. Be aware that certain heatsinks may not have sufficient clearance to work alongside this memory.
Finally, this is the included active memory cooler. This consists of two 60mm fans, powered by a single 3 pin connector. With four bolts, the unit fixes itself to the RAM using two brackets. The installation itself is very simple although you may have trouble fitting the unit with certain CPU coolers.
Next stop, overclocking!
Originally Posted by name='Daylightdon'
Should the latency numbers be higher or lower? What do they mean?
regardsQuote
WTG Corsair !
