Corsair Dominator GT 1600MHz AM3 Review
SiSoft Sandra & WinRAR
Synthetic Benchmarks Part 1
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC.
CPU Arithmetic
The CPU arithmetic test ascertains the processor's capabilities in terms of numerical operations. Two subtests named Dhrystone and Whetstone are carried out respectively. This is not a measure of latency and thus higher is better
Well how boring is that? A flat graph...
This is of course a heavily CPU dependent benchmark and so this is very much to be expected. Small gains are seen when comparing the three frequency and timing configurations although once you factor in error margins, these are truly insignificant differences.
CPU Multimedia
The CPU Multimedia Test focuses on CPU based operations that may occur during multimedia based tasks. The magnitude of the score depends on the processor's ability to handle Integer, Float and Double data types.
A similar story can be found here. Again, the nature of this test means that (within reason) RAM does not have a huge bearing on the overall result.
Memory Performance
Next we examined Memory Latency...
On an AM3 platform with a Phenom II @ 2000MHz NB, these results are very much what you'd expect for RAM of this calibre. Given that the IMC has been left at nominal frequencies, it is nice to see that ~13.5GB/sec has been achieved.
 WinRAR
 WinRAR's embedded Benchmark focuses on the processor's File Compression capability.
WinRAR appears to take great advantage of tighter memory timings and higher memory frequencies. The gains shown are much higher than we would have expected.
«Prev 1 2 3 4 5 6 7 Next»
02-07-2010, 10:59:59
alienware
You can just tell that has been designed for recent ROG boards
WTG Corsair ! Quote
02-07-2010, 11:11:46
tinytomlogan
Aye if the AMD's dont like high speed ram or at least overclocking the ram for high speeds then low latency just makes alot of sense.Quote
03-07-2010, 11:36:48
silenthill
this ram is could boost your systems gaming performance specially for AMD platforms which suffer when compared to Intel's platforms.Quote
04-07-2010, 13:37:26
Daylightdon
Should the latency numbers be higher or lower? What do they mean?Quote
04-07-2010, 14:11:40
silenthill
The latency numbers should be lower because the AMD processor memory controller can’t deal with high speed memory so the only thing that will improve performance is to lower the memory latency which means it will respond in less time to orders that come from the CPU so the lower the better. I have tried low latency memory on a 965 AMD CPU and it did improve the performance.
regardsQuote
