G.Skill FLARE PC3-16000 Memory Review
SiSoft Sandra
CPU Performance
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC.
CPU Arithmetic
The CPU arithmetic test ascertains the processor's capabilities in terms of numerical operations. Two subtests named Dhrystone and Whetstone are carried out respectively. This is not a measure of latency and thus higher is better.
The Arithmetic test shows frequency of memory taking precedence; albeit the difference remains marginal.
CPU Multimedia
The CPU Multimedia Test focuses on CPU based operations that may occur during multimedia based tasks. The magnitude of the score depends on the processor's ability to handle Integer, Float and Double data types
Meanwhile the Multimedia test takes a preference towards memory latency.
Memory Bandwidth
In terms of SiSoft's memory bandwidth test, the results are near enough level.
Memory Latency
Without surprise, the G.Skill configuration at 7-7-6-20 timings offers the lowest memory latencies.
«Prev 1 2 3 4 5 6 7 Next»
08-10-2010, 13:58:57
AndrewJohnRegan
The problem with the RAM not going to up to 2000Mhz might be that your motherboard is not specified as being compatible with the RAM. Only selected boards have been comfirmed of being able to run these fellas at 'full':
ASUS M4A89TD PRO
ASUS M4A89GTD PRO
ASUS M4A88TD-V EVO/USB3
*The Asus Crosshair Formula is also compatible, though it does not say so on the compatible motherboards list.
Sorry btw if im just stating the obvious to you though matey. I'm probably just being a .Quote
08-10-2010, 14:59:03
SnW
You might want to read it again Andrew Quote
08-10-2010, 15:08:59
AndrewJohnRegan
What have I said wrong then haa, knew i'd mess up somewhere. Quote
09-10-2010, 15:23:33
silenthill
I’d really like a picture of the ram installed with fan on the M/B so we can compare them to the Corsair but I guess that’s too much to ask these days
Quote
