G.Skill FLARE PC3-16000 Memory Review
Everest Ultimate Edition
CPU Queen
CPU Queen is based on branch prediction and the misprediction penalties that are involved.
CPU Photoworxx
PhotoWorxx as the name may suggest tests processors by means of invoking functions that are common to Photo Manipulation including Fill, Flip, Crop, Rotate, Difference and Colour to B&W conversion.
CPU ZLib
This is an integer based benchmark that will test the CPU and Memory by means of the CPU ZLib compression library.
The Everest Ultimate Edition series of processor benchmarks show memory making a negligible difference. Pehaps the tests pertaining to core memory operations will offer more interesting results.
Memory Bandwidth
Both the tighter timing set and higher memory frequencies offer a larger memory bandwidth result over the Kingston set.
Memory Latency
Interestingly the memory latency results show similar results regardless of frequency or timing configuration. Lets move on to more general system benchmarks.
«Prev 1 2 3 4 5 6 7 Next»
08-10-2010, 13:58:57
AndrewJohnRegan
The problem with the RAM not going to up to 2000Mhz might be that your motherboard is not specified as being compatible with the RAM. Only selected boards have been comfirmed of being able to run these fellas at 'full':
ASUS M4A89TD PRO
ASUS M4A89GTD PRO
ASUS M4A88TD-V EVO/USB3
*The Asus Crosshair Formula is also compatible, though it does not say so on the compatible motherboards list.
Sorry btw if im just stating the obvious to you though matey. I'm probably just being a .Quote
08-10-2010, 14:59:03
SnW
You might want to read it again Andrew Quote
08-10-2010, 15:08:59
AndrewJohnRegan
What have I said wrong then haa, knew i'd mess up somewhere. Quote
09-10-2010, 15:23:33
silenthill
I’d really like a picture of the ram installed with fan on the M/B so we can compare them to the Corsair but I guess that’s too much to ask these days
Quote
